[GRASS5] [patch] resize bug in X monitor
Magnus B{ckstr|m
b at etek.chalmers.se
Tue Apr 30 13:45:06 EDT 2002
the below patch corrects a bunnyhop error in XDRIVER and updates
G_malloc() a little.
The bunnyhop error caused a bus error when resizing an X monitor on
freebsd, and the update to G_malloc() ensures that returned memory
is initialized to zeros (which not all malloc()s can be trusted to
do).
Magnus
Index: src/display/devices/XDRIVER/XDRIVER24/Serve_Xevent.c
RCS file: /home/grass/grassrepository/grass/src/display/devices/XDRIVER/XDRIVER2
4/Serve_Xevent.c,v
retrieving revision 1.7
diff -c -r1.7 Serve_Xevent.c
*** src/display/devices/XDRIVER/XDRIVER24/Serve_Xevent.c 16 Feb 2002 07:2
2:56 -0000 1.7
--- src/display/devices/XDRIVER/XDRIVER24/Serve_Xevent.c 30 Apr 2002 17:1
8:15 -0000
*** 234,240 ****
static void handleResizeEvent(void)
! PAD *curpad;
char buf[64];
XWindowAttributes xwa;
XGCValues gc_values;
--- 234,241 ----
! FILE *_f;
! PAD *curpad, *nextpad;
char buf[64];
*** 254,262 ****
delete_item(curpad,"cur_w");
/* delete all other pads */
! for ( curpad = pad_list(); curpad != NULL; curpad = curpad->next )
if ( *curpad->name )
delete_pad(curpad);
curpad = NULL;
--- 255,266 ----
! for ( curpad = pad_list(); curpad != NULL; curpad = nextpad )
! nextpad = curpad->next;
delete_pad(curpad);
curpad = NULL;
Index: src/libes/gis/alloc.c
RCS file: /home/grass/grassrepository/grass/src/libes/gis/alloc.c,v
retrieving revision 1.2
diff -c -r1.2 alloc.c
*** src/libes/gis/alloc.c 22 Jan 2002 12:01:06 -0000 1.2
--- src/libes/gis/alloc.c 30 Apr 2002 17:18:45 -0000
*** 59,65 ****
if (n <= 0) n = 1; /* make sure we get a valid request */
buf = malloc(n);
! if(buf) return buf;
G_fatal_error ("G_malloc: out of memory");
return NULL;
--- 59,68 ----
buf = malloc(n);
! if(buf) {
! bzero(buf, n); /* Don't trust malloc to initialize buffer. */
! return buf;
return NULL;
