[GRASS5] [bug #1033] (grass) motif and configure
Glynn Clements
glynn.clements at virgin.net
Tue Apr 30 13:59:34 EDT 2002
Markus Neteler wrote:
> > 3. Or are we discussing the OpenGL widget library (lib*GLw*)? Which is
> > a separate problem to either OpenGL or Motif.
> Yes, this problem remains (GLwCreateMDrawingArea is needed for compilation):
> configure ... --with-glw
> checking whether to use GLw... yes
> checking for location of GLw includes...
> checking for GL/GLwMDrawA.h... yes
> checking for location of GLw library...
> checking for GLwCreateMDrawingArea in -lGLw... no
> checking for GLwCreateM1DrawingArea in -lGLw... no
> checking for GLwCreateM2DrawingArea in -lGLw... no
> checking for GLwCreateMDrawingArea in -lGLwM... no
> checking for GLwCreateM1DrawingArea in -lGLwM... no
> checking for GLwCreateM2DrawingArea in -lGLwM... no
> configure: error: *** Unable to locate GLwM library.
> On my Redhat box is
> locate GLw
[snip]
> /usr/lib/libMesaGLw.a
I'll check for that as well, but does that library include the Motif
widget (use "nm /usr/lib/libMesaGLw.a")? If not, you will need
libMesaGLwM.a.
Glynn Clements <glynn.clements at virgin.net>
