[GRASS5] [bug #1228] (grass) Floats for XY regions!
Request Tracker
grass-bugs at intevation.de
Wed Aug 7 17:58:35 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1228
Subject: Floats for XY regions!
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5pre4
after defining a region like
N:1 S:-1 W:-1.75 E:0.25 NSRES&EWRES:0.1
in a XY location, another run of "g.region",option=1 will most likely result in a display of
N:1,S:-1,W:2,E:0, NSRES&EWRES: illegal distance
even WITHOUT changing the above mentioned parameters.
A possible solution would be to make the regions dimension FLOATS insteads of INTs.
Cheers,
Peter
[Why the funny numbers? -> GRASS can *even* be used to calculate Mandelbrot sets]
-------------------------------------------- Managed by Request Tracker
