[GRASS5] Objections to release 5.0.0stable?
Glynn Clements glynn.clements at virgin.net
Fri Aug 9 17:25:47 EDT 2002
Eric G. Miller wrote:
> > I was under the impression that this is an IrisGL vs OpenGL issue. The
> > OpenGL headers are absolutely definitely <GL/gl.h> and <GL/glu.h>.
> > But, I think that SG3d is IrisGL.
> I had this vague recollection about Windows having <gl/*.h>, but then
> maybe that doesn't matter due to the general case insensitive nature
> of the platform??
Yes. It's supposed to be <GL/gl.h>; using <gl/gl.h> will work on
Windows, but it isn't correct (unfortunately, many programmers don't
understand the distinction between "works for me" and "correct").
Glynn Clements <glynn.clements at virgin.net>
