[GRASS5] Objections to release 5.0.0stable?
Glynn Clements
glynn.clements at virgin.net
Sat Aug 10 16:36:51 EDT 2002
Markus Neteler wrote:
> > > are there any objections to release 5.0.0stable?
> > > I can't see release critical bugs.
> > > If no objections, we should tar the ball,
> > First, we should check whether any important fixes still need to be
> > merged into the release branch.
> Yes, certainly (I was silently including the somewhat common procedure,
> silently hoping for your assistance :-)
OK. I've analysed the diffs:
1. These are entirely harmless documentation fixes.
documents/parameter_proposal.txt
Additional comments
documents/release_rules.txt
Add "rename 'grass' directory to 'grass5.0.0XXX'"
Change upload location to grass.itc.it
html/html/g.gisenv.html
s/grass4/grass5/
html/html/i.ortho.photo.html
Number menu entries
html/html/r.in.gdal.html
Misc. updates
html/projections.html
Add krovak, krovakgis
html/vector.html
Add v.label
2. These are simple fixes which I'm recommending (i.e. they will be
merged unless someone objects).
src/display/devices/CELL/Graph_Clse.c
src/display/devices/CELL/Graph_Set.c
Fix crash bug
src/libes/edit/edit_cellhd.c
double -> void
X-Y fix
src/imagery/i.class/curses.c
src/imagery/i.ortho.photo/photo.2image/curses.c
src/imagery/i.ortho.photo/photo.2target/curses.c
src/imagery/i.points/curses.c
src/imagery/i.vpoints/curses.c
Change parameter name from "true" to "ok".
src/libes/gis/flate.c
Use #error instead of invalid code
src/libes/ogsf/GS2.c
In GS_unset_att(): gs->mask_needupdate = 1; [bug #1196]
src/mapdev/v.digit/remove_block.c
Add " (y/n)" to prompt
src/raster/r.colors/cmd/main.c
Document "byr" type
src/scripts/contrib/v.plant/v.plant
Recognise --help
src/raster/r.proj/cmd/bordwalk.c
src/raster/r.proj/cmd/main.c
src/raster/r.proj/cmd/r.proj.h
Finish bordwalk fixes
3. I need more information on these, but they seem sufficiently minor
to be uncontentious.
NEWS.html
Document fixes since pre5
[Some of the changes which are documented here are up for discussion;
the NEWS.html which is supplied with 5.0.0 should only mention changes
which actually make it into the release.]
src.garden/grass.postgresql/tutorial/index.html
Change "destroydb" to "dropdb"
html/database.html
add r.to.pg
remove v.in.shape.pg
src.garden/grass.postgresql/Gmakefile
Disable v.in.shape.pg
src.contrib/GMSL/NVIZ2.2/scripts/panel_cutplane.tcl
??? log message is:
Bob Covill: fix for z scale range: bug #1202
html/html/d.dm.html
src/display/d.dm/d.dm
add PNG feature
src.garden/answers/src.answers/raster/Gmakefile
src.garden/answers/src.answers/raster/r.answers/inter/Gmakefile
src.garden/answers/src.answers/raster/r.answers/inter/answers_input.c
src.garden/answers/src.answers/raster/r.answers/inter/answers_run.c
src.garden/answers/src.answers/raster/r.answers/inter/bmp_menu.c
src.garden/answers/src.answers/raster/r.answers/inter/copy_project.c
src.garden/answers/src.answers/raster/r.answers/inter/edit_region.c
src.garden/answers/src.answers/raster/r.answers/inter/extract.c
src.garden/answers/src.answers/raster/r.answers/inter/extract_bmp.c
src.garden/answers/src.answers/raster/r.answers/inter/extract_chnl_slp.c
src.garden/answers/src.answers/raster/r.answers/inter/extract_rain.c
src.garden/answers/src.answers/raster/r.answers/inter/extract_tile.c
src.garden/answers/src.answers/raster/r.answers/inter/get_bmp.c
src.garden/answers/src.answers/raster/r.answers/inter/get_channel.c
src.garden/answers/src.answers/raster/r.answers/inter/get_chnl_slp.c
src.garden/answers/src.answers/raster/r.answers/inter/get_cover.c
src.garden/answers/src.answers/raster/r.answers/inter/get_elevation.c
src.garden/answers/src.answers/raster/r.answers/inter/get_mask.c
src.garden/answers/src.answers/raster/r.answers/inter/get_outlet.c
src.garden/answers/src.answers/raster/r.answers/inter/get_rain.c
src.garden/answers/src.answers/raster/r.answers/inter/get_res.c
src.garden/answers/src.answers/raster/r.answers/inter/get_soils.c
src.garden/answers/src.answers/raster/r.answers/inter/get_tile.c
src.garden/answers/src.answers/raster/r.answers/inter/hit_return.c
src.garden/answers/src.answers/raster/r.answers/inter/hydro_filter.c
src.garden/answers/src.answers/raster/r.answers/inter/map_sediment.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_bmp_tbl.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_cat_tbl.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_chnl_tbl.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_cover_tbl.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_elev.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_rain.c
src.garden/answers/src.answers/raster/r.answers/inter/mk_soil_tbl.c
src.garden/answers/src.answers/raster/r.answers/inter/read_project.c
src.garden/answers/src.answers/raster/r.answers/inter/remove_files.c
src.garden/answers/src.answers/raster/r.answers/inter/set_mask.c
src.garden/answers/src.answers/raster/r.answers/inter/set_region.c
src.garden/answers/src.answers/raster/r.answers/inter/show_status.c
src.garden/answers/src.answers/raster/r.answers/inter/step1.c
src.garden/answers/src.answers/raster/r.answers/inter/trim_region.c
src.garden/answers/src.answers/raster/r.answers/inter/user_file.c
src.garden/answers/src.answers/raster/r.slope/cmd/Gmakefile
src.garden/answers/src.answers/raster/r.slope/inter/Gmakefile
Appears to be just s/stdout/stderr/ and Gmakefile fixes
4. These seem to be more substantial upgrades, so I'm more sceptical
about including them.
html/html/r.info.html
src/raster/r.info/cmd/main.c
HTML fixes
-r flag
html/html/m.in.e00.html
src/misc/m.in.e00/info.c
src/misc/m.in.e00/main.c
list= option
Other fixes ???
+ html/html/r.to.pg.html
src/scripts/contrib/r.to.pg/r.to.pg
Add HTML file
Support attribute cats
src/display/d.vect/cmd/main.c
src/display/d.vect/cmd/plot2.c
src/display/d.vect/cmd/plotCat.c
locale/ru/LC_MESSAGES/d.vect.pg.po
html/html/d.vect.pg.html
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
-e flag
locale/ru/LC_MESSAGES/v.to.pg.po
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
src.garden/grass.postgresql/v.to.pg/runInfxFile.c
-p flag (PostGIS)
html/html/d.text.freetype.html
src/display/d.text.freetype/Gmakefile
src/display/d.text.freetype/freetypecap
src/display/d.text.freetype/main.c
+ src/display/d.text.freetype/test.input
+ src/display/d.text.freetype/vflib
new options: align=, rotation=, -r, -p, -s, -c
command mode
html/html/ps.map.html
src/ps.map/ps.map/cmd/Gmakefile
src/ps.map/ps.map/cmd/colortable.h
src/ps.map/ps.map/cmd/ctablfile.c
src/ps.map/ps.map/cmd/eps.c
src/ps.map/ps.map/cmd/local_proto.h
src/ps.map/ps.map/cmd/ps_area.c
src/ps.map/ps.map/cmd/ps_map.c
src/ps.map/ps.map/cmd/read_cfg.c
src/ps.map/ps.map/cmd/vectfile.c
src/ps.map/ps.map/cmd/vector.h
+ src/ps.map/ps.map/cmd/ps_fclrtbl.c
Add height option to "colortable" command
Add pat, pwidth, scale options to "vector" command
Support FP colour tables.
5. The remainder are I18N fixes to key components (libgis, startup,
tcltkgrass). If they break anything, they may well break everything,
so I'm opposed to including them in the 5.0.0 release.
locale/Gmakefile
Add tcltkgrass textintro targets
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
+ src/general/init/license.txt
src/general/init/Gmakefile
src/general/init/init.sh
I18N
+ locale/ru/tcltkgrass
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
I18N
locale/ru/LC_MESSAGES/libgis.po
src/libes/gis/Gmakefile
src/libes/gis/G_dump.c
src/libes/gis/adj_cellhd.c
src/libes/gis/ask.c
src/libes/gis/ask_cell.c
src/libes/gis/auto_mask.c
src/libes/gis/cats.c
src/libes/gis/closecell.c
src/libes/gis/color_read.c
src/libes/gis/datum.c
src/libes/gis/done_msg.c
src/libes/gis/env.c
src/libes/gis/error.c
src/libes/gis/format.c
src/libes/gis/get_cellhd.c
src/libes/gis/get_datum.c
src/libes/gis/get_datum_name.c
src/libes/gis/get_ell_name.c
src/libes/gis/get_ellipse.c
src/libes/gis/get_projinfo.c
src/libes/gis/get_projname.c
src/libes/gis/get_row.c
src/libes/gis/get_window.c
src/libes/gis/gishelp.c
src/libes/gis/gisinit.c
src/libes/gis/histogram.c
src/libes/gis/history.c
src/libes/gis/home.c
src/libes/gis/legal_name.c
src/libes/gis/list.c
src/libes/gis/location.c
src/libes/gis/make_colr.c
src/libes/gis/mapset.c
src/libes/gis/mapset_msc.c
src/libes/gis/mask_info.c
src/libes/gis/myname.c
src/libes/gis/null_val.c
src/libes/gis/opencell.c
src/libes/gis/parser.c
src/libes/gis/proj2.c
src/libes/gis/proj3.c
src/libes/gis/put_cellhd.c
src/libes/gis/put_row.c
src/libes/gis/put_title.c
src/libes/gis/quant_io.c
src/libes/gis/quant_rw.c
src/libes/gis/range.c
src/libes/gis/rd_cellhd.c
src/libes/gis/readsites.c
src/libes/gis/readsites_xyz.c
src/libes/gis/reclass.c
src/libes/gis/set_window.c
src/libes/gis/system.c
src/libes/gis/timestamp.c
src/libes/gis/view.c
I18N
Glynn Clements <glynn.clements at virgin.net>
