[GRASS5] Objections to release 5.0.0stable?
Markus Neteler
neteler at itc.it
Sun Aug 11 17:08:59 EDT 2002
On Sat, Aug 10, 2002 at 09:36:51PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > are there any objections to release 5.0.0stable?
> > > > I can't see release critical bugs.
> > > > If no objections, we should tar the ball,
> > > First, we should check whether any important fixes still need to be
> > > merged into the release branch.
> > Yes, certainly (I was silently including the somewhat common procedure,
> > silently hoping for your assistance :-)
> OK. I've analysed the diffs:
Thanks for this, Glynn!
> 1. These are entirely harmless documentation fixes.
I suggest to submit them to the release branch.
> 2. These are simple fixes which I'm recommending (i.e. they will be
> merged unless someone objects).
Also these I suggest to submit to the release branch.
> 3. I need more information on these, but they seem sufficiently minor
> to be uncontentious.
> NEWS.html
> Document fixes since pre5
> [Some of the changes which are documented here are up for discussion;
> the NEWS.html which is supplied with 5.0.0 should only mention changes
> which actually make it into the release.]
> src.garden/grass.postgresql/tutorial/index.html
> Change "destroydb" to "dropdb"
This is an HTML file and a documentation fix only (AFAIK 'destroydb'
doesn't exist any more). So: yes.
> html/database.html
> add r.to.pg
> remove v.in.shape.pg
both yes.
> src.garden/grass.postgresql/Gmakefile
> Disable v.in.shape.pg
also yes (see discussion in ML). To keep this will confuse the user.
> src.contrib/GMSL/NVIZ2.2/scripts/panel_cutplane.tcl
> ??? log message is:
> Bob Covill: fix for z scale range: bug #1202
