[GRASS5] Objections to release 5.0.0stable?
Bob Covill bcovill at tekmap.ns.ca
Mon Aug 12 08:25:36 EDT 2002
Markus Neteler wrote:
>       src.contrib/GMSL/NVIZ2.2/scripts/panel_cutplane.tcl
>               ??? log message is:
>                       Bob Covill: fix for z scale range: bug #1202
Markus;
The above fix should be fine. It was some basic TCL callbacks between
the entries and the Z scale and XY locations. It did fix the initial
problem.
It was later reported that the actual function (called from TCL) was not
working correctly. This will be a problem in the src or ogsf, which I
have not had time to investigate.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
