[GRASS5] Objections to release 5.0.0stable?
Eric G. Miller
egm2 at jps.net
Mon Aug 12 21:19:24 EDT 2002
On Mon, Aug 12, 2002 at 09:59:58PM +0100, Glynn Clements wrote:
> > > src.garden/grass.postgresql/tutorial/index.html
> > > Change "destroydb" to "dropdb"
> > This is an HTML file and a documentation fix only (AFAIK 'destroydb'
> > doesn't exist any more). So: yes.
> Not applied.
> Presumably this is related to the PostgreSQL version. I have
> PostgreSQL 6.5.3, which has "destroydb" but not "dropdb".
> We can't know which version the user has, so the documentation should
> probably say something like:
> To destroy a database use: "destroydb humus" (PostgreSQL 6.x)
> or "dropdb humus" (PostgreSQL 7.x).
Or, "psql -c 'DROP DATABASE humus' template1"? Should work in either.
Similarly "psql -c 'CREATE DATABASE humus' template1" ...
Focuses a little more on the SQL than on postres tools ... maybe.
Eric G. Miller <egm2 at jps.net>
