[GRASS5] Objections to release 5.0.0stable?
Radim Blazek blazek at itc.it
Tue Aug 13 04:49:26 EDT 2002
On Monday 12 August 2002 10:59 pm, Glynn Clements wrote:
> > > 	html/html/d.dm.html
> > > 	src/display/d.dm/d.dm
> > > 		add PNG feature
> > Looks as not to be dangerous. Did someone test that new button?
> > But I'm not shure.
> Not applied.
> The code does:
> 	d.mon PNG
> 	<draw maps>
> 	d.mon stop=PNG
> 1. If the PNG driver is already in use, this is bad.
Was not so bad, but I added check for running PNG monitor (restarted).
> 2. Should it be re-selecting the previous monitor when it finishes, or
> is that taken care of elsewhere?
Elsewhere.
But obviously PNG in d.m is a new feature not bug fix so it is correct that
it was not applied.
Radim
