[GRASS5] [bug #1232] (grass) r.out.ppm3 improperly registers
Request Tracker
grass-bugs at intevation.de
Wed Aug 14 08:52:13 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1232
Subject: r.out.ppm3 improperly registers
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0pre5
Using the r.out.ppm3 option impropery registers. I attempted to reimport the ppm image, without changing region parameters, and get:
WARNING: G_set_window(): Illegal latitude for North
ERROR: region for current mapset is invalid
line 3: <north: 1866N>
run "g.region"
Of course, a latitude 1866N is not proper. The original rgb rasters display properly, and running r.info, find that they have lat/lon's that are reasonable.
-------------------------------------------- Managed by Request Tracker
