[GRASS5] Re: [bug #1231] (grass) g.copy bug: cell_misc ignored
Glynn Clements
glynn.clements at virgin.net
Wed Aug 14 17:23:02 EDT 2002
Markus Neteler wrote:
> > > GRASS:~ >l ~/grassdata/pat/PERMANENT/cell_misc/test
> > > ls: /ssi0/ssi/neteler/grassdata/pat/PERMANENT/cell_misc/test: No such file or
> > > directory
> > Er, shouldn't this be "modis" instead of "PERMANENT"?
> Er, yes. Sorry, but....
> > AFAICT, g.copy *does* copy the cell_misc/<map> directory (assuming
> > that it's in etc/element_list).
> You are right. The problem is still there, but different:
> GRASS:~ > l /ssi0/ssi/neteler/grassdata/pat/neteler/cell_misc/test
> total 4
> -r--r--r-- 1 neteler ssi 10 Aug 14 14:25 range
> GRASS:~ > r.support -r test
> Updating the stats for [test]
> WARNING: can't write range file for [test in neteler]
> Updating the number of categories for [test]
> The permissions should be
> -rw-r--r--
> right? That's the real problem where I was struggling.
I suspect that adding:
chmod u+rw $b
after the line:
cp $a $b
in src/general/manage/lib/copy.sh should solve the immediate problem.
However, this wouldn't be specific to the cell_misc files. AFAICT, all
files retain their permissions when copied. The obvious question is:
why was the original range file read-only?
Also, that script (in fact, almost *every* script) should really have
double quotes around all of the variable expansions, i.e.
cp "$a" "$b"
This particular issue is likely to be the source of around half of the
bugs relating to spaces in pathnames. The other half are due to the
use of sprintf/system.
In the longer term, src/general/manage should be completely
re-written. Much of the code there is suspect, even by GRASS'
standards.
Glynn Clements <glynn.clements at virgin.net>
