[GRASS5] Objections to release 5.0.0stable?
Glynn Clements
glynn.clements at virgin.net
Tue Aug 20 17:44:09 EDT 2002
Glynn Clements wrote:
> > > > are there any objections to release 5.0.0stable?
> > > > I can't see release critical bugs.
> > > > If no objections, we should tar the ball,
> > > First, we should check whether any important fixes still need to be
> > > merged into the release branch.
> > Yes, certainly (I was silently including the somewhat common procedure,
> > silently hoping for your assistance :-)
> OK. I've analysed the diffs:
Below is a list of the outstanding differences which, in the absence
of arguments to the contrary, won't make it into the release.
Glynn Clements <glynn.clements at virgin.net>
NEWS.html
Document fixes since pre5
html/html/m.in.e00.html
src/misc/m.in.e00/info.c
src/misc/m.in.e00/main.c
html/html/d.vect.pg.html
locale/ru/LC_MESSAGES/d.vect.pg.po
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
-e flag
locale/ru/LC_MESSAGES/v.to.pg.po
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
src.garden/grass.postgresql/v.to.pg/runInfxFile.c
-p flag (PostGIS)
html/html/d.dm.html
src/display/d.dm/d.dm
add PNG feature
+ src/display/d.text.freetype/vflib
+ src/display/d.text.freetype/test.input
html/html/d.text.freetype.html
src/display/d.text.freetype/Gmakefile
src/display/d.text.freetype/freetypecap
src/display/d.text.freetype/main.c
new options: align=, rotation=, -r, -p, -s, -c
command mode
src/display/d.vect/cmd/main.c
src/display/d.vect/cmd/plot2.c
src/display/d.vect/cmd/plotCat.c
html/html/d.legend.html
src/tcltkgrass/module/d.legend
src/display/d.leg.thin/main.c
src/scripts/contrib/d.rast.leg/d.rast.leg
-o flag (only show used categories)
maxfontsize= option
fix d.rast.leg script (use g.gisenv to obtain GISDBASE/LOCATION_NAME/MAPSET)
html/html/ps.map.html
+ src/ps.map/ps.map/cmd/ps_fclrtbl.c
src/ps.map/ps.map/cmd/Gmakefile
src/ps.map/ps.map/cmd/colortable.h
src/ps.map/ps.map/cmd/ctablfile.c
src/ps.map/ps.map/cmd/eps.c
src/ps.map/ps.map/cmd/local_proto.h
src/ps.map/ps.map/cmd/ps_area.c
src/ps.map/ps.map/cmd/ps_map.c
src/ps.map/ps.map/cmd/read_cfg.c
src/ps.map/ps.map/cmd/vectfile.c
src/ps.map/ps.map/cmd/vector.h
Add height option to "colortable" command
Add pat, pwidth, scale options to "vector" command
Support FP colour tables.
+ html/html/r.to.pg.html
src/scripts/contrib/r.to.pg/r.to.pg
Add HTML file
Support attribute cats
src/tcltkgrass/todo/r.colortool/r.colortool
Use g.gisenv to obtain GISDBASE/LOCATION_NAME/MAPSET
locale/Gmakefile
Add tcltkgrass textintro targets
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
+ src/general/init/license.txt
src/general/init/Gmakefile
src/general/init/init.sh
Startup i18n
+ locale/ru/tcltkgrass
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
tcltkgrass i18n
+ locale/ru/LC_MESSAGES/libgis.po
src/libes/gis/Gmakefile
src/libes/gis/G_dump.c
src/libes/gis/adj_cellhd.c
src/libes/gis/ask.c
src/libes/gis/ask_cell.c
src/libes/gis/auto_mask.c
src/libes/gis/cats.c
src/libes/gis/closecell.c
src/libes/gis/color_read.c
src/libes/gis/datum.c
src/libes/gis/done_msg.c
src/libes/gis/env.c
src/libes/gis/error.c
src/libes/gis/format.c
src/libes/gis/get_cellhd.c
src/libes/gis/get_datum.c
src/libes/gis/get_datum_name.c
src/libes/gis/get_ell_name.c
src/libes/gis/get_ellipse.c
src/libes/gis/get_projinfo.c
src/libes/gis/get_projname.c
src/libes/gis/get_row.c
src/libes/gis/get_window.c
src/libes/gis/gishelp.c
src/libes/gis/gisinit.c
src/libes/gis/histogram.c
src/libes/gis/history.c
src/libes/gis/home.c
src/libes/gis/legal_name.c
src/libes/gis/list.c
src/libes/gis/location.c
src/libes/gis/make_colr.c
src/libes/gis/mapset.c
src/libes/gis/mapset_msc.c
src/libes/gis/mask_info.c
src/libes/gis/myname.c
src/libes/gis/null_val.c
src/libes/gis/opencell.c
src/libes/gis/parser.c
src/libes/gis/proj2.c
src/libes/gis/proj3.c
src/libes/gis/put_cellhd.c
src/libes/gis/put_row.c
src/libes/gis/put_title.c
src/libes/gis/quant_io.c
src/libes/gis/quant_rw.c
src/libes/gis/range.c
src/libes/gis/rd_cellhd.c
src/libes/gis/readsites.c
src/libes/gis/readsites_xyz.c
src/libes/gis/reclass.c
src/libes/gis/set_window.c
src/libes/gis/sites.c
src/libes/gis/system.c
src/libes/gis/timestamp.c
src/libes/gis/view.c
libgis i18n
