[GRASS5] Re: [GRASSLIST:4357] merge of lines
Bernhard Reiter bernhard at intevation.de
Thu Aug 22 07:13:31 EDT 2002
It seems that there is not option in v.digit -> edit
to join two lines that share a node.
Is there a reason for this in the data model?
It should be fairly easy to do.
Like if I have two lines .= vertices X=node shared by both lines
	.----.----X--.--.
to join the lines to
If I wanted to add this, what would I have to do?
On Thu, Aug 22, 2002 at 10:21:58AM +0200, Monika Schunke wrote:
> I cannot find any tool to merge vectorlines. Does not GRASS have any
> tools for that?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020822/8b986b46/attachment.bin
