[GRASS5] [bug #1107] (grass) v.digit locks if the terminal is too small
Markus Neteler neteler at itc.it
Fri Aug 23 10:21:26 EDT 2002
On Fri, Aug 23, 2002 at 03:23:33PM +0200, Bernhard Reiter via RT wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1107
> Request number 1107 was commented on by 'bernhard' (Bernhard Reiter).
> Responding to this message will send mail to the requestor.
> 			Request Tracker
> 			rt at intevation.de
> Cc: grass5 at grass.itc.it
> Maybe we should add a check for the terminal size for v.digit.
This I tried, but I didn't understand how to do it (curses
didn't give me the numbers as suggested by Glynn). An expert
is needed here :-)
Markus
> At least a warning in the man page would be appropriate.
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
