[GRASS5] release branch testers wanted (tarball provided)
    Markus Neteler
    neteler at itc.it
    Tue Aug 27 03:12:35 EDT 2002
On Tue, Aug 27, 2002 at 12:38:41AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > my build-script now compiles separated a 24bit PNG driver:
> > I had to hardcode library paths inside
> Hardcoding paths doesn't fix anything; it just makes it look that way
> to you (because your /usr/local/lib/libgd.so is GD 2.x).
> The right approach is to give the GD 2.x library a soname of
> "libgd.so.2", by adding "-Wl,-soname,libgd.so.2" to the linking flags.
Thanks for this hint! But were to add it (sorry, speak slowly please).
I tried to add it in PNGdriver/Gmakefile but it still picks up
the wrong lib:
gmake5
gcc -L/hardmnt/thuille1/ssi/cvsgrass_exp/src/libes/LIB.i686-pc-linux-gnu  -o
/ssi0/ssi/neteler/cvsgrass_exp/dist.i686-pc-linux-gnu/driver/PNG
OBJ.i686-pc-linux-gnu/Can_do.o OBJ.i686-pc-linux-gnu/Clr_table.o
OBJ.i686-pc-linux-gnu/Color.o OBJ.i686-pc-linux-gnu/Draw_line.o
OBJ.i686-pc-linux-gnu/Get_w_box.o OBJ.i686-pc-linux-gnu/Get_w_line.o
OBJ.i686-pc-linux-gnu/Get_w_pnt.o OBJ.i686-pc-linux-gnu/Graph_Clse.o
OBJ.i686-pc-linux-gnu/Graph_Set.o OBJ.i686-pc-linux-gnu/Panel.o
OBJ.i686-pc-linux-gnu/Polygn_abs.o -ldriver -lgis -lz   -L/usr/local/lib
-lgd -lfreetype   -ljpeg   -lpng  -lz  -lm -Wl,-soname,libgd.so.2
[sorry, I don't know anything about this soname trick]
ldd /ssi0/ssi/neteler/cvsgrass_exp/dist.i686-pc-linux-gnu/driver/PNG
        libgd.so => /usr/lib/libgd.so (0x40017000)
ls -l /usr/lib/libgd.so
lrwxrwxrwx 1 root root 14 Aug  1  2001 /usr/lib/libgd.so -> libgd.so.1.8.3
> It should also have dependency information, which is obtained by
> adding the necessary "-l" switches to the link command (although this
> isn't strictly necessary; configure should handle all of the many
> possible combinations of optional libraries).
> Realistically, we need to provide a fixed version of GD 2.x along with
> the 24-bpp version of the PNG driver.
> The alternative is to simply state that GD 2.x is unsupported, until
> either the GD developers fix the problems, or OS vendors start
> shipping GD 2.x (the OS vendors will handle the version problems
> themselves if the GD developers don't).
Well, even for us here at IRST I need a solution, an 8bit PNG driver
ist just too poor.
Markus
