[GRASS5] [bug #1465] (grass) v.proj datum conversion fails. Typo in code main.c
Markus Neteler via RT grass-bugs at intevation.de
Wed Dec 4 04:33:15 EST 2002
Eric has submitted the C changes.
I have submitted the tcltkgrass changes, thanks.
It's true (but wanted?) that -l doesn't work in tcltkgrass.
Reason is
 if(isatty(0))  /* check if on command line */
(line 217).
Should we remove that if condition?
 Markus
-------------------------------------------- Managed by Request Tracker
