[GRASS5] [bug #1465] (grass) v.proj datum conversion fails. Typo in code main.c
Glynn Clements
glynn.clements at virgin.net
Wed Dec 4 13:01:54 EST 2002
Markus Neteler via RT wrote:
> Eric has submitted the C changes.
> I have submitted the tcltkgrass changes, thanks.
> It's true (but wanted?) that -l doesn't work in tcltkgrass.
> Reason is
> if(isatty(0)) /* check if on command line */
> (line 217).
> Should we remove that if condition?
Yes.
Glynn Clements <glynn.clements at virgin.net>
