[GRASS5] [bug #1465] (grass) v.proj datum conversion fails. Typo in code main.c
Markus Neteler neteler at itc.it
Thu Dec 5 10:16:36 EST 2002
On Wed, Dec 04, 2002 at 06:01:54PM +0000, Glynn Clements wrote:
> Markus Neteler via RT wrote:
> > Eric has submitted the C changes.
> > I have submitted the tcltkgrass changes, thanks.
> > It's true (but wanted?) that -l doesn't work in tcltkgrass.
> > Reason is
> >  if(isatty(0))  /* check if on command line */
> > (line 217).
> > Should we remove that if condition?
> Yes.
Done.
Markus
PS: Have also extended #25 in SUBMITTING as suggested.
