[GRASS5] [bug #1496] (grass) tcltkgrass: balloons obscure menu subitems etc.
Request Tracker
grass-bugs at intevation.de
Wed Dec 25 23:10:44 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1496
GRASS 5.0.0pre4 (May 2002) debian
I'm using tcltkgrass and as I move the pointer along the bar at the
top of the window, the little helper balloons that pop up often
obscure the subitems or even main item.
BTW, pressing on MISC and moving straight down will get one stuck in
the coordinate conversions menu, as it is stuck on the edge of my 800
wide monitor, thus anti-indented, and blocking the further menu items,
which one has to make a loop motion to get to...
BTW, there is no safeguards from the user invoking a second
tcltkgrass... no questions "are you serious?"
There is no way to close tcltkgrass from the menus.
One must reach for the X button in the corner, which indeed was a
little off my 800 wide screen....wait!, I see it now, "Quit"... it was
off the edge!
I hit display->map scale in monitor, and get a poorly placed cutoff
error window.
I display a raster map and this box comes up and I pick 'save'.
it saves a two byte empty file.
I try again and notice it has forgotten the directory i just
painstakingly chose, etc...
I choose display profile, and notice i have to reenter the name of the
raster map i just put in the display,
BTW, the button marked 'raster' might be more commonly marked
'select'...
I pick 'quit' and pick to stop all monitors but it didn't stop
it... maybe because i still had the unanswered raster question box on
the screen,
i had to use d.mon to close it.
http://jidanni.org/ Taiwan(04)25854780
--- Headers Follow ---
>From jidanni at dman.ddts.net Thu Dec 26 05:10:44 2002
Return-Path: <jidanni at dman.ddts.net>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 18450139C1
for <grass-bugs at lists.intevation.de>; Thu, 26 Dec 2002 05:10:44 +0100 (CET)
Received: from tx.symonds.net (tx.symonds.net [64.246.28.87])
by mail.intevation.de (Postfix) with ESMTP id 8C4C21C258
for <grass-bugs at intevation.de>; Thu, 26 Dec 2002 05:10:42 +0100 (CET)
Received: from tc210-203-44-241.3-16.pl.ebtnet.net ([210.203.44.241] helo=debian)
by tx.symonds.net with asmtp (Exim 4.04)
id 18RPM0-00051d-00
for grass-bugs at intevation.de; Wed, 25 Dec 2002 23:10:41 -0500
Received: from jidanni by debian with local (Exim 3.36 #1 (Debian))
id 18RPIO-0002CW-00
for <grass-bugs at intevation.de>; Thu, 26 Dec 2002 12:06:56 +0800
To: grass-bugs at intevation.de
Subject: tcltkgrass: balloons obscure menu subitems etc.
User-Agent: Gnus/5.09 (Gnus v5.9.0) Emacs/21.2
Date: Thu, 26 Dec 2002 12:06:56 +0800 01:00:00 +0000 (GMT)
Message-ID: <87isxhpgnz.fsf at jidanni.org>
Lines: 39
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-1.0 required=5.0
tests=SIGNATURE_SHORT_DENSE,SPAM_PHRASE_00_01,USER_AGENT,
USER_AGENT_GNUS_UA
version=2.43
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
