[GRASS5] d.vect.area
Eric G. Miller
egm2 at jps.net
Sun Feb 3 19:26:45 EST 2002
I've modified d.vect.area a little. Two things may be of interest to you.
One is the possibility of specifying the "legend" file via standard
input by using "legend=-". The other is the addition of boundary line
drawing. The legend file is backwards compatible, with line colors
being specified as a second set of RGB values:
<cat> R G B [ R G B ]
24 255 255 255 139 139 139
48 255 0 0
Also, the legend file can now contain comments and blank lines.
There's no way to specify a default boundary color without specifying
a default fill color.
Other changes:
"-r" now is really a randomized selection from a small color palette. Always
draws boundaries in black. Fill colors are never black or white. Otherwise,
very similar to standard GRASS colors.
linecolor : corresponding boundary color argument if "color" is used for
a constant fill color.
Eric G. Miller <egm2 at jps.net>
