[GRASS5] d.vect.area
Glynn Clements glynn.clements at virgin.net
Sun Feb 3 20:00:01 EST 2002
Eric G. Miller wrote:
> I've modified d.vect.area a little.  Two things may be of interest to you.
> One is the possibility of specifying the "legend" file via standard
> input by using "legend=-".
Warning: if you do this, you need to massage the command string which
is passed to D_add_to_list().
Glynn Clements <glynn.clements at virgin.net>
