[GRASS5] d.vect.area
Eric G. Miller egm2 at jps.net
Sun Feb 3 20:29:33 EST 2002
On Mon, 4 Feb 2002 01:00:01 +0000, Glynn Clements <glynn.clements at virgin.net> wrote:
> Eric G. Miller wrote:
> > I've modified d.vect.area a little.  Two things may be of interest to you.
> > One is the possibility of specifying the "legend" file via standard
> > input by using "legend=-".
> Warning: if you do this, you need to massage the command string which
> is passed to D_add_to_list().
Massage how?  I do see the problem though.  Maybe I should take that out?
Eric G. Miller <egm2 at jps.net>
