[GRASS5] strange things on cmd line
Bernhard Reiter
bernhard at intevation.de
Thu Feb 7 06:52:49 EST 2002
On Thu, Feb 07, 2002 at 09:56:57AM +0100, Markus Neteler wrote:
> On Wed, Feb 06, 2002 at 05:39:43PM -0700, Roger Miller wrote:
> > On Wednesday 06 February 2002 15:31, Markus Neteler wrote:
> > > Hi,
> > > today I found something unusual (maybe my error?):
> > Command line continuation (are not) should be determined by your
> > shell, not by GRASS. If it is a problem, then would it be
> > GRASS's problem or a problem with the shell?
> I have been using "\" successfully with other commands in GRASS (in bash).
> Only s.surf.rst fails. Probably a parsing problem in that module?
If shell continuation works, the program will see exactly the same
as with a long line. Make sure you do not have anything on the line
after the backslash.
There might be a problem with parsing spaces and tabs in the module
if the above does not solve the problem.
For illustration see the following tests:
$ echo $BASH_VERSION
2.03.0(1)-release
$ echo bla bla bla | od -tcx
0000000 b l a b l a b l a \n
20616c62 20616c62 0a616c62
0000014
bernhard at abnoba:~$ echo bla bla\
> bla | od -tcx
0000014
bernhard at abnoba:~$ echo bla bla \
> bla | od -tcx
0000014
Bernhard
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020207/45ac595f/attachment.bin
