[GRASS5] strange things on cmd line
Markus Neteler
neteler at itc.it
Fri Feb 8 12:39:34 EST 2002
Thanks to all who helped with my s.surf.rst problem.
I fact there was a "blank" after \, now it's running well.
Markus
On Thu, Feb 07, 2002 at 12:52:49PM +0100, Bernhard Reiter wrote:
> On Thu, Feb 07, 2002 at 09:56:57AM +0100, Markus Neteler wrote:
> > On Wed, Feb 06, 2002 at 05:39:43PM -0700, Roger Miller wrote:
> > > On Wednesday 06 February 2002 15:31, Markus Neteler wrote:
> > > > Hi,
> > > > today I found something unusual (maybe my error?):
> > > Command line continuation (are not) should be determined by your
> > > shell, not by GRASS. If it is a problem, then would it be
> > > GRASS's problem or a problem with the shell?
> > I have been using "\" successfully with other commands in GRASS (in bash).
> > Only s.surf.rst fails. Probably a parsing problem in that module?
> If shell continuation works, the program will see exactly the same
> as with a long line. Make sure you do not have anything on the line
> after the backslash.
> There might be a problem with parsing spaces and tabs in the module
> if the above does not solve the problem.
> For illustration see the following tests:
> $ echo $BASH_VERSION
> 2.03.0(1)-release
> $ echo bla bla bla | od -tcx
> 0000000 b l a b l a b l a \n
> 20616c62 20616c62 0a616c62
> 0000014
> bernhard at abnoba:~$ echo bla bla\
> > bla | od -tcx
> 0000014
> bernhard at abnoba:~$ echo bla bla \
> > bla | od -tcx
> 0000014
> Bernhard
> Professional Service for Free Software (intevation.net)
> The FreeGIS Project (freegis.org)
> Association for a Free Informational Infrastructure (ffii.org)
> FSF Europe (fsfeurope.org)
