bug #783: nviz segmentation violation (was [GRASS5] nviz / tcl compile problem)
Markus Neteler
neteler at itc.it
Thu Feb 14 08:11:20 EST 2002
On Thu, Feb 14, 2002 at 12:58:19PM +0000, M Lennert wrote:
> On 13 Feb 02, at 11:32, Markus Neteler wrote:
> > On Wed, Feb 13, 2002 at 10:22:44AM +0000, M Lennert wrote:
> > > Hello,
> > Moritz: try to comment line 36 in tkInt8.2.3.h.
> I did this and the sources compiled, but now I get the following error:
Moritz,
can you check the tk version? It is defined in
/usr/include/tk.h
Probably you are not using 8.2.3, but something similar
(means that we have to add another tkInt8.2.X.h).
Markus
> Loading Data
> Update elev null mask
> Loading Data
> building color table
> Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
> while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
> ("eval" body line 1)
> invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
> invoked from within
> "if {$argv == ""} {
> #no arguments
> eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
> (file "/usr/local/grass5/bin/nviz" line 13)
> This is the error documented in bug #783 which was declared resolved as fo 5.0.0pre2. Any ideas ?
> Moritz
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
