bug #783: nviz segmentation violation (was [GRASS5] nviz / tcl compile problem)
Bernhard Reiter
bernhard at intevation.de
Thu Feb 14 08:17:07 EST 2002
On Thu, Feb 14, 2002 at 02:11:20PM +0100, Markus Neteler wrote:
> On Thu, Feb 14, 2002 at 12:58:19PM +0000, M Lennert wrote:
> > On 13 Feb 02, at 11:32, Markus Neteler wrote:
> > > On Wed, Feb 13, 2002 at 10:22:44AM +0000, M Lennert wrote:
> > > > Hello,
> > > Moritz: try to comment line 36 in tkInt8.2.3.h.
> > I did this and the sources compiled, but now I get the following error:
> Moritz,
> can you check the tk version? It is defined in
> /usr/include/tk.h
> Probably you are not using 8.2.3, but something similar
> (means that we have to add another tkInt8.2.X.h).
I can only hope that we remove code from tcl/tk distributions
from the GRASS codebase as soon as possible.
It will be a nightmare to maintain and support.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020214/cf3fbae7/attachment.bin
