bug #783: nviz segmentation violation (was [GRASS5] nviz / tcl compile problem)
Markus Neteler
neteler at itc.it
Thu Feb 14 08:27:17 EST 2002
On Thu, Feb 14, 2002 at 02:17:07PM +0100, Bernhard Reiter wrote:
> On Thu, Feb 14, 2002 at 02:11:20PM +0100, Markus Neteler wrote:
> > On Thu, Feb 14, 2002 at 12:58:19PM +0000, M Lennert wrote:
> > > On 13 Feb 02, at 11:32, Markus Neteler wrote:
> > > > On Wed, Feb 13, 2002 at 10:22:44AM +0000, M Lennert wrote:
> > > > > Hello,
> > > > Moritz: try to comment line 36 in tkInt8.2.3.h.
> > > I did this and the sources compiled, but now I get the following error:
> > Moritz,
> > can you check the tk version? It is defined in
> > /usr/include/tk.h
> > Probably you are not using 8.2.3, but something similar
> > (means that we have to add another tkInt8.2.X.h).
> I can only hope that we remove code from tcl/tk distributions
> from the GRASS codebase as soon as possible.
> It will be a nightmare to maintain and support.
Bernhard,
On Wed, Feb 13, 2002 at 09:28:17PM +0100, Bernhard Reiter wrote:
>We can offer a convinient package
>with the headers, but the base line has to be that this is not GRASS' fault.
do you think of providing a tcl/tk binaries package including the
additional header file? That's not fully clear to me.
If yes, it will be another dependency for GRASS as the standard
tcl/tk package delivered on Linux distros would be needed to be replaced.
You also had to prepare such a package for all the architectures and
OSes, right? Or am I missing something?
If we "just" add the missing header files to NVIZ, we are at least
compliant up to tcl/tk8.3. But let me know, it seems I didn't understand
your proposal :-)
Markus
