[GRASS5] [bug #921] (grass) tcltkgrass3.2 dted extraction west input error
Request Tracker
grass-bugs at intevation.de
Fri Feb 15 12:21:02 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=921
Subject: tcltkgrass3.2 dted extraction west input error
Platform: Linux/Intel
Linux distro: RedHat
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: GNOME
TclTk version: tcl/tk 8.3
grass downloaded at: Baylor site
grass binary for platform: Linux/Intel binaries
When trying to extract DTED files into binary raster using the option under Misc->DEM/DTED->DTED Extraction, the resulting pop-up menu which requires the file and region coordinates to be inputted, has the last input line wrong. It is labeled as North longitude region when it should be West longitude region. Whatever is inputted here is reflected in the above North latitude input box. Thus, when you hit run, the resulting error message says that "required parameter <west> not set". This needs to be corrected before DTED files can be read in successfully using Tcltkgrass.
-------------------------------------------- Managed by Request Tracker
