[GRASS5] small configure problem on solaris 8 sparc
Andreas Lange
Andreas.Lange at Rhein-Main.de
Mon Feb 25 10:10:00 EST 2002
there is a minor problem with the new configure on solaris 8:
Solaris echo does not recognize the -n option. So the output of
configure (listing of libraries) is garbled.
This is a problem with LOC_MSG from configure.in resp. aclocal.m4. I
know a fix, but don't know how to implement this with aclocal.m4:
if test `echo "one \c" | wc -w` eq 2 ; then
ECHO="echo -n"
EL=""
else
ECHO="echo"
EL="\c"
fi
echo has to be replaced with:
$ECHO "this is a message $EL"
Thanks,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.lycos.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
