[GRASS5] v.in.shape missing some polygons
Gualter Barbas Baptista
gualter at netcabo.pt
Tue Feb 26 20:18:06 EST 2002
Your solution ("hacking" the file in dig_att) worked perfectly! After
two days trying to figure out a solution to this, it's really good to
see all those polygons drawed.
This bug should be on the top priority for fixing ;)
Thanks,
Gualter
David D Gray wrote:
> Gualter Barbas Baptista wrote:
>> Is there some workaround for this (like exporting to some other
>> format with Arcview) while it's not fixed?
>> Thanks,
>> Gualter
> Can you get a script to export as e00? That should have the properly
> deconstructed linework, and attributes with topology already built, so
> it is then, if all else is OK, a direct import into GRASS. Similarly
> for DLG (there never used to be a DLG export for GRASS, but it's a
> while since I looked), or maybe SDTS.
> Otherwise, there are some tools, like XTools, that can export the
> `centroids' as a point theme. These are a set of representative
> interior points, one for each polygon, not true centroids in the
> geometric sense, so can be used to carry the attributes of the
> associated polygons.
> If you include the X and Y readings in the theme database, then that
> can be converted to a text file easily and you then have the data you
> need.
> This next bit is a bit `hacky', but I occasionally use it myself for
> various reasons:
> 1) Use something like `awk' or `sed' to morph the lines of text in the
> text file created above so each line has the following fields, in this
> order with spaces separating:
> A <X-coord> <Y-coord> <your chosen numeric attribute>
> Note the `A' is literal and *must* be uppercase.
> 2) Drop this manually into the dig_att directory as a file with the
> name of the target polygon coverage. This will probably replace the
> existing file (which you might want to back up).
> 3) Rebuild the map with `v.support option=build'.
> You can carry out the above three stages with a sites_list file as
> well, if you import the centroids coverage with s.in.shape. But some
> people have reported this gives errors as well, on some platforms.
> David
>>>> When I import shapefiles using v.in.shape almost everything goes
>>>> ok, except for some polygons, that show up the lines, but have no
>>>> values, which means that when I convert the vector file to raster
>>>> there is nothing. I tried changing the colinearity tolerance and
>>>> the snap distance, but the result is the same.
>>>> I tried exporting one of these images back as a E00 and the
>>>> polygons that didn't show up had a value of zero. I changed
>>>> manually the values to 1 and re-exported to shapefile, imported in
>>>> GRASS, etc. and I got the same result.
>>>> Is this some known bug or am I doing something wrong?
>>>> Thanks,
>>>> Gualter
>>> Hi
>>> It is a known bug. It happens when a polygon is imported after all
>>> the surounding polygons have been imported. This was originally a
>>> `feature' to try and get round the annoying frequency with which (at
>>> least older versions of) ArcView generated multiple copies of the
>>> same polygon, usually simple island polygons. Unfortunately it had
>>> this side-effect for some cell-like polygons, ie those with many
>>> neighbours.
>>> The next release of v.in.shape should be free of this.
>>> David
>>> grass5 mailing list
>>> grass5 at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
