[GRASS5] [bug #886] (grass) d.frame -l (=frame.list) dumps core/does not work
guest user via RT
grass-bugs at intevation.de
Fri Jan 4 11:34:22 EST 2002
Hi Andreas, Glynn
did you recompile both XDRIVER with lib and d.frame?
There was an update recently. But, Glynn, a small fix
seems to be needed:
d.erase
d.frame -l
ERROR: can not get "list" items
rast:
vect:
site:
d.rast wakedem30
100%
d.frame -l
rast:wakedem30 at markus
vect:
site:
Thanks for reporting this,
Markus
-------------------------------------------- Managed by Request Tracker
