[GRASS5] [bug #886] (grass) d.frame -l (=frame.list) dumps core/does not work
Glynn Clements
glynn.clements at virgin.net
Fri Jan 4 15:49:01 EST 2002
guest user via RT wrote:
> did you recompile both XDRIVER with lib and d.frame?
> There was an update recently. But, Glynn, a small fix
> seems to be needed:
> d.erase
> d.frame -l
> ERROR: can not get "list" items
d.erase deletes all pads.
I.e. there aren't any frames following d.erase (D_setup() will create
the "full_screen" frame if there is no current frame).
Apart from fixing frame.list, there's the question of whether d.erase
should re-create some of the pads which it deletes. This relates to
the issue of d.save not reporting the window following d.erase.
Glynn Clements <glynn.clements at virgin.net>
