[GRASS5] [bug #883] (grass) configure dosn't look for yacc
Glynn Clements glynn.clements at virgin.net
Fri Jan 4 15:14:59 EST 2002
Markus Neteler wrote:
> > On the subject of lex/flex, configure.in currently has the following:
> > if test "$LEX" != "flex"; then
> >     AC_MSG_WARN([Consider installation of flex (replacement of lex).])
> > fi
> > Does anyone know the reason for this message?
> > If the .l files *need* flex, then this should be an error. OTOH, if
> > they work with lex, there doesn't seem much point in issuing a
> > warning.
> the reason is that we had problems with "yylineno" in the past (if
> I recall properly). In:
> src/raster/r.binfer/binfer.l
OK; currently, the references to yylineno are commented out.
If the line number is required, it's probably better to include code
to track it, rather than have (f)lex do it for you.
> Flex provides something which is not always provided by lex.
AFAIK, AT&T lex does provide yylineno, but it is undocumented;
yylineno isn't part of the POSIX specification for lex.
Also, the flex manpage states that "%option yylineno" results in a
significant performance penalty (although control files aren't
generally large enough to be worth bothering about performance).
Glynn Clements <glynn.clements at virgin.net>
