[bug #887] (grass) Re: [GRASS5] r.neighbors: works with reclass maps?
Request Tracker
grass-bugs at intevation.de
Fri Jan 4 12:34:51 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=887
On Wed, Jan 02, 2002 at 09:35:28PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > while using r.neighbors on reclassed maps (from r.reclass)
> > I got some strange results.
> Are you referring to the result map being almost entirely null?
> E.g.
> r.neighbors -z input=soils.Kfactor output=foo method=minimum size=5
> produces a map which is null except for the very left-hand edge, while
> r.mapcalc 'sk=soils.Kfactor'
> r.neighbors -z input=sk output=foo method=minimum size=5
> seems to work OK.
> > Is it possible that we have
> > to added a test into r.neighbors? Or is it a local problem
> > only?
> The bug is in libgis.
> The call to G_get_d_raster_row() in readcell.c returns only NaN for
> the original (reclass) "soils.Kfactor" map, but sensible values for
> the (non-reclass) "sk" map.
> I've tracked this down to the double use of a static buffer
> (G__.mask_buf) in G_get_raster_row().
> For reclass maps, G_get_raster_row() uses G__.mask_buf as a temporary
> buffer. It calls G_get_c_raster_row(G__.mask_buf), which in turn calls
> embed_nulls(G__.mask_buf), which calls G_get_null_value_row().
> However, G_get_null_value_row uses G__.mask_buf itself (via the macro
> MASK_BUF) to hold the mask row.
> Summary: static "work buffers" are a bad idea.
> Unfortunately, some systems don't support alloca(), and some of those
> which do don't make it straightforward to use. autoconf has a
> solution, but it's messy. And using malloc()/free() for short-lived
> buffers could significantly harm performance.
> For the time being, I guess that we'll have to just add another static
> work buffer for the purpose of reclass maps. However, I'm not yet sure
> of the mechanism used for allocating and reallocating such buffers.
Glynn,
thanks for looking into this! Do you see a chance to work
around? I have seen some malloc tests in other "configures"
such as GDAL etc. Perhaps they have a functional autoconf
implementation?
Markus
--- Headers Follow ---
>From neteler at itc.it Fri Jan 4 18:34:51 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id ED4B3139D0
for <grass-bugs at lists.intevation.de>; Fri, 4 Jan 2002 18:34:50 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id C23191B96B
for <grass-bugs at intevation.de>; Fri, 4 Jan 2002 18:34:49 +0100 (CET)
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g04HYld26544;
Fri, 4 Jan 2002 18:34:47 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id g04HYjx13745;
Fri, 4 Jan 2002 18:34:46 +0100 (MET)
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g04HYj517478;
Fri, 4 Jan 2002 18:34:45 +0100
Date: Fri, 4 Jan 2002 18:34:45 +0100
To: Glynn Clements <glynn.clements at virgin.net>
Cc: grass5 developers list <grass5 at grass.itc.it>,
Subject: Re: [GRASS5] r.neighbors: works with reclass maps?
Message-ID: <20020104183445.A3608 at itc.it>
Mail-Followup-To: Glynn Clements <glynn.clements at virgin.net>,
References: <20020102181947.J3608 at itc.it> <15411.32032.689209.584267 at cerise.nosuchdomain.co.uk>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <15411.32032.689209.584267 at cerise.nosuchdomain.co.uk>; from glynn.clements at virgin.net on Wed, Jan 02, 2002 at 09:35:28PM +0000
X-Spam-Status: No, hits=0 required=5 tests=SUBJ_ENDS_IN_Q_MARK
-------------------------------------------- Managed by Request Tracker
