[GRASS5] v.in.shape/mif - the sequel
David D Gray
ddgray at armadce.demon.co.uk
Sun Jan 6 12:36:03 EST 2002
>>>>on the source tree, but I can't find any reference to common dbm types.
>>>>Does anyone see any problem with #include'ing dbm.h on any particular
>>>>platform? Especially useful would be information about non-Gnu
>>>>platforms. GNU systems like linux, cygwin should pick up gdbm which is good.
>>>Anyway, I'm not aware of any addition of dbm since you last worked on
>>>GRASS. I don't see any problem adding it, but maybe help out with
>>>configure rules?
>>It would at least need to check both -ldbm and -lgdbm (I don't know
>>about ndbm). Alternate library checks are already done for FFTW
>>(-lfftw, -ldfftw) and Tcl/Tk (-ltcl, -ltcl<version>).
>>I can add the configure.in rules if desired.
> I've added the checks for DBM.
> config.h should define HAVE_DBM_H, and the head file will define
> DBMINCPATH (any -I switches), DBMLIBPATH (any -L switches) and DBMLIB
> (-ldbm, -lgdbm or -lndbm) for use in Gmakefiles. I put libndbm last
> as, on GNU systems, this may actually be a link to libdb (which
> includes a DBM interface to Berkeley DB ("NEWDB") files).
> Note: if dbm.h isn't in one of the standard include directories, you
> need to use "--with-dbm-includes=..." (RH6.2 puts it in
> /usr/include/gdbm). If you don't have it, you can use --without-dbm to
> disable the checks.
Glynn,
Thanks. So now I can port the dbm using into stable v.in.shape as well.
David
