[GRASS5] Grass 5.1
Markus Neteler neteler at itc.it
Tue Jan 8 04:56:57 EST 2002
On Mon, Jan 07, 2002 at 09:26:33PM +0100, Radim Blazek wrote:
> On Monday 07 January 2002 14:34, you wrote:
> > Hi Radim,
> > Still this error is remaining:
> > make[4]: Entering directory
> > /amd/cage0/ssi/BIO/software/GRASS5.0.0/grass51/lib/db/sqlp/test'
> > make[4]: *** No rule to make target 'sqlp', needed by
> > /ssi0/ssi/neteler/grass51/dist.i686-pc-linux-gnu/etc/bin/cmd/sqltest'.
> > Stop.
> >  -> no Makefile in CVS, please upload (I guess you have it)
> Commited.
> > Then I have fixed
> > tools/link.conf
> > for the current XDRIVER in stable branch. However, a library
> > link seems to be missing in Makefile. I can't compile that
> > yet.
> It is impossible to have g51 compilable with both stable and devel branch,
> and because devel tree contains new features we must link
> g51 to g50devel !!!!
Radim,
sorry - that was not clear to me (please add a comment in INSTALL).
My suggestion is to immediately merge back the XDRIVER and monitor
to devel tree, then g51 and g50 are sync'ed again (and we don't
miss the important improvements in XDRIVER).
The merge back of the other modules may follow then after getting
this experience.
Glynn, what do you think?
> display/driver/lib is needed only because of driverlib.h and doesn't need to
> be compiled.
> > Another suggestion:
> >  Let us put the display drivers into lib/ as they are no modules.
> >  I never liked them in 5.0 to live in driver/ directory.
> OK, I don't insist on that location.
> There is test location on:
> http://www.raz-dva.cz/krakonos/g51test-1.tar.gz
> Start grass51, select test1 mapset, go to location dir and try scripts:
> ./io
> ./display
> (see README).
I will try that directly when the current problem is solved.
If we want to wait more time with the merge back, I will have
to revert my recent changes in grass51 to get it functional
against the current devel tree again.
Excuse me for this confusion,
 Markus
