[GRASS5] GRASS: make install problems
Markus Neteler
neteler at itc.it
Thu Jan 10 12:17:02 EST 2002
> > > a user reported that, when installing GRASS with
> > > make install
> > > some permissions are wrong.
> > > He compilied as "root" and installed (make install).
> > > The permissions for
> > > /opt/grass5/tcltkgrass/script/gis_set.tcl
> > > /opt/grass5/bin/tcltkgrass
> > > were not right for the normal users. As I am installing
> > > GRASS as normal user, I cannot verify this.
> > > Does anyone know about this problem? Do we have
> > > to fix a missing "chmod"?
> > I don't see any problem ("make" as user, "make install" as root).
> > However, note that "make install" mostly just copies the files to the
> > installation directory. The installed files will have the same
> > ownership and permissions as the versions in dist.<platform>.
> > For files which aren't generated by compilation (e.g. scripts), they
> > will probably have the ownership and permissions resulting from
> > installation (i.e. "tar x" or "cvs checkout/update").
> Well, the build procedure for tcltkgrass is:
> make[1]: Entering directory `<SRC>/tcltkgrass'
> if [ ! -d <DST>/tcltkgrass ]; then mkdir <DST>/tcltkgrass; fi
> rm -f <DST>/bin/tcltkgrass
> tar cf - docs/Pro* docs/HIS* main/* module/* script/* | (cd <DST>/tcltkgrass; tar xf -)
> cp main/gis_set.tcl <DST>/tcltkgrass/script
> cp tcltkgrass <DST>/bin/tcltkgrass
> chmod ugo+x <DST>/tcltkgrass/main/tksys.tcl
> chmod ugo+x <DST>/bin/tcltkgrass
> chmod -R u+w <DST>/tcltkgrass
> make[1]: Leaving directory `<SRC>/tcltkgrass'
> where <SRC> is the GRASS "src" directory and <DST> is the
> dist.<platform> directory.
> IOW, "make" simply copies everything into the staging directory, from
> where "make install" will copy it to the final $GISBASE directory. So,
> the ownership and permissions will be the same as the source files,
> minus any permission bits which are cleared by way of the umask
> setting.
> It would probably suffice to add "chmod -R ugo+rX ${INST_DIR}" to the
> end of the "install" target.
So,
now "my" user sent me the permissions:
before:
-rw-r----- 1 root root /opt/grass5/tcltkgrass/script/gis_set.tcl
-rwxr-x--x 1 root root /opt/grass5/bin/tcltkgrass
after:
-rw-r----- 1 root users /opt/grass5/tcltkgrass/script/gis_set.tcl
-rwxr-x--x 1 root users /opt/grass5/bin/tcltkgrass
Additionally all files in /opt/grass5/tcltkgrass/script
except gis_set.tcl got the wrong owner.
As this seems to happen on several machines, we should consider to
modify the install script.
Markus
