[GRASS5] XDRIVER pad list and d.rast
Markus Neteler
neteler at itc.it
Sun Jan 13 04:37:42 EST 2002
On Sat, Jan 12, 2002 at 02:51:31PM -0800, Eric G. Miller wrote:
> On Sat, 12 Jan 2002 22:52:47 +0100, Markus Neteler <neteler at itc.it> wrote:
> > Hi,
> > after working in a GRASS session for some more time without
> > d.erase I realized by resizing the monitor, that some
> > 20 display commands had been accumulated (generally fine!).
> > My question/suggestion is: If
> > d.rast map
> > is used, can't this be used to erase the command list in GRASS
> > monitor? As d.rast will overwrite everything (am I wrong?) it's
> > effectively the same as
> > d.erase
> > d.rast map
> Have you never used d.rast to display more than one adjacent or
> overlapping raster? I think the answer to that question will
> answer your question ;-)
Sorry, Eric,
I was not very precise. Of course I know the difference:
d.rast -o somemap
was *not* meant. I should have written that I only think of
a pure:
d.rast map
If -o is used, the list in monitor should be kept of course.
Am I still missing something? :-)
Markus
