[GRASS5] XDRIVER pad list and d.rast
Eric G. Miller egm2 at jps.net
Sat Jan 12 17:51:31 EST 2002
On Sat, 12 Jan 2002 22:52:47 +0100, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> after working in a GRASS session for some more time without
> d.erase I realized by resizing the monitor, that some
> 20 display commands had been accumulated (generally fine!).
> My question/suggestion is: If
> d.rast map
> is used, can't this be used to erase the command list in GRASS
> monitor? As d.rast will overwrite everything (am I wrong?) it's
> effectively the same as
> d.erase
> d.rast map
Have you never used d.rast to display more than one adjacent or
overlapping raster?  I think the answer to that question will
answer your question ;-)
Eric G. Miller <egm2 at jps.net>
