[GRASS5] XDRIVER pad list and d.rast
Markus Neteler
neteler at itc.it
Sat Jan 12 16:52:47 EST 2002
after working in a GRASS session for some more time without
d.erase I realized by resizing the monitor, that some
20 display commands had been accumulated (generally fine!).
My question/suggestion is: If
d.rast map
is used, can't this be used to erase the command list in GRASS
monitor? As d.rast will overwrite everything (am I wrong?) it's
effectively the same as
d.erase
d.rast map
Just a suggestion for redraw convenience,
maybe I oversee something,
Markus
