[GRASS5] some thoughts
Glynn Clements
glynn.clements at virgin.net
Fri Jan 18 03:26:29 EST 2002
Roger Bivand wrote:
> > Ultimately you can only get so much integration before separate
> > processes start to become a problem. But eliminating the exit() calls,
> > opportunities for fatal errors[1] and memory leaks isn't going to
> > happen overnight.
> > [1] By which I basically mean crashes. G_fatal_error() can be modified
> > to allow a "fatal" error handler to be installed which could call
> > setjmp() rather than exit(). This would allow "exception" style error
> > handling rather than having to pass NULL/-1/whatever all the way up
> > the call stack.
Of course, I meant longjmp().
> The R interface "takes over" error handling from libgis.a as:
> void R_G_init(char *name) {
> G_set_error_routine(R_handler);
> G_sleep_on_error(0);
> G_gisinit(name);
> with R_handler() being a simple function that passes the error on within
> R.
Right; you've already done that bit.
I was thinking about supporting pushing/popping error handlers, along
with try/catch/throw macros. Given that most code just gives up and
quits as soon as something goes wrong, status returns mostly just make
the code ugly.
> If modules never use exit() but only G_fatal_error(), this works
> smoothly in my experience.
Unfortunately, a fair amount of code currently just calls exit(). But
that isn't hard to change, just a lot of donkey work.
Glynn Clements <glynn.clements at virgin.net>
