[GRASS5] Want GNU libavl ?
Bernhard Reiter bernhard at intevation.de
Mon Jan 21 05:19:01 EST 2002
If two developers people need that library
we should plan to integrate it.
The idea using a wrapper library might turn out to be the way.
What is the reason that the author does not
want libavl to be dynamically linked?
	Bernhard
On Mon, Jan 21, 2002 at 10:34:22AM +0100, Andrea Aime wrote:
> Ah, BTW, I'm not willing to rewrite them just to make
> them look better, the fact is that s.voronoi has a bug
> that I'm not able to track down and s.delaunay doesn't
> support constrained triangulation...
> Andrea Aime wrote:
> > Mmm, I'm planning a full rewrite of s.voronoi, s.delaunay
> > I need a priority queue and a balanced tree and
> > I was considering using the code available at www.purists.org
> > were also an AVL tree is available...
> > Should we put togheter a little container library for GRASS
> > that could be statically linked into the executables?
> > ----- Original Message -----
> > From: "Eric G. Miller" <egm2 at jps.net>
> > To: "GRASS5" <grass5 at grass.itc.it>
> > Sent: Monday, January 21, 2002 5:03 AM
> > Subject: [GRASS5] Want GNU libavl ?
> > > Working on the polygon simplification problem, I needed a balanced tree
> > > to get efficient (n log n) sorted insert/retrieval.  Anyway, I grabbed
> > > Ben Pfaff's libavl 2.0, and it is working out pretty nicely.
> > > I was wondering if it isn't something we might not want to add to the
> > > GRASS repository (note: Ben writes the "library" is intended to be
> > > included in code directly rather than distributed as a shared library).
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020121/34325fc8/attachment.bin
