[GRASS5] Want GNU libavl ?
Eric G. Miller
egm2 at jps.net
Mon Jan 21 16:13:14 EST 2002
On Mon, 21 Jan 2002 11:19:01 +0100, Bernhard Reiter <bernhard at intevation.de> wrote:
> If two developers people need that library
> we should plan to integrate it.
> The idea using a wrapper library might turn out to be the way.
> What is the reason that the author does not
> want libavl to be dynamically linked?
I don't think the author is necessarily against it. Basically
each tree type has it's own source file, so I guess the idea
was take what you want and leave the rest. It seems the
author was at least as interested in producing the book about
trees and ways to implement them (including how he did it).
The book is pretty lengthy...
Eric G. Miller <egm2 at jps.net>
