[GRASS5] Want GNU libavl ?
Eric G. Miller
egm2 at jps.net
Mon Jan 21 16:18:08 EST 2002
On Mon, 21 Jan 2002 20:33:21 +0100, Andrea Aime <aaime at libero.it> wrote:
> Alle 19:12, lunedì 21 gennaio 2002, David D Gray ha scritto:
> > Actually there is a simple binary tree from way back. Maybe a btree has
> > been added recently, I don't know, but we do need better container
> > support. I first came across this when I started on the import filters a
> > couple years back. In fact I first linked the v.in.shape binary against
> > Berkeley DB2 btree, which gave a good result, but introducing it at that
> > time was potentially a large job, and there were questions of platform
> > support and its a big package to bundle if it's to become a dependency.
> > So I agree that a number of different containers could be included, and
> > it would also be good to have some kind of uniformity in the interface
> > to these, like a system of wrapper functions.
> Yes, I fully agree in principle. The problem is that I'm not aware of any
> C equivalent of the STL, I mean, a set of container classes with consistent
> interfaces. The containers mentioned above are coming from two different
> libraries (libavl, www.purists.org), and if we need some other data
> structures some other sources
> could be used, coming from more different plances (which may lead to more
> confusion, at least in principle...)
> Is there anyone who is aware of a usable (GPL'd, LGPL'd) container library
> for the C programming language?
The latest GLib is probably the closest I can think of. It has hashes, trees,
sets, etc... The reason I went with libavl, is it is purportedly better
optimised for the balanced trees, and it's simple to include the files you
need (two in my case).
Eric G. Miller <egm2 at jps.net>
