[GRASS5] Projection transform
Lee Wilson and Associates
abq at lwasf.com
Wed Jan 23 11:11:59 EST 2002
Morten Hulden wrote:
> I hope anyone who tackles m.proj[2] will consider that there also is
> common code with g.setproj.
> A few years ago when I added support for more projections in g.setproj, I
> also made corresponding changes in m.proj and merged the init routines
> into the gis library. Now these program have started to drift apart again
> - basic datum shift support has partially been added to g.setproj but not
> to m.proj.
> I believe , based on the similarity of the code and some old module
> no longer present in the current distro, that in the ancient past (long
> before I started to use grass) g.setproj and m.proj was the same program.
Now g.setproj and m.proj don't even perform similar tasks. g.setproj
lets the user set the projection information associated with a database
location and m.proj converts coordinates between different projections.
I guess I don't see much reason why these tasks should be merged.
Roger Miller
> Morten Hulden
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
