[GRASS5] Some strange HTML online output
Markus Neteler neteler at itc.it
Thu Jan 24 08:14:36 EST 2002
On Thu, Jan 24, 2002 at 02:09:43PM +0100, Bernhard Reiter wrote:
> On Thu, Jan 24, 2002 at 01:11:32PM +0100, Markus Neteler wrote:
> > Hi,
> > while looking at the HTML man pages:
> > http://grass.itc.it/gdp/html_grass5/html/p.map.html
> > http://grass.itc.it/gdp/html_grass5/html/p.map.new.html
> > some strange output occurs:
> > Menu for /gdp/html_grass5/html/p.map.html
> >           html
> > [an internal server error occured]
> > Obviously these pages are treated as something different
> > (PHP?).
> > Any ideas to solve this?
> Check the log file(s) of the server for messages.
> You might need to turn on debugging information for this.
> > The HTML code is o.k., I think.
> It most certainly is a configuration problem of the webserver
Looking into error_log:
[Thu Jan 24 14:07:45 2002] [error] [client 140.XXX] map file
/gdp/html_grass5/html/p.map.new.html, line 2 syntax error: requires at least
two fields
 -> map file?
Or course
http://grass.itc.it/gdp/html_grass5/html/ps.map.html
is also not readable.
The "map" in the filename confuses the Apache. But why (sorry,
yes, I could browse the web)?
Markus
