[GRASS5] Some strange HTML online output
Glynn Clements
glynn.clements at virgin.net
Thu Jan 24 08:50:24 EST 2002
Markus Neteler wrote:
> while looking at the HTML man pages:
> http://grass.itc.it/gdp/html_grass5/html/p.map.html
> http://grass.itc.it/gdp/html_grass5/html/p.map.new.html
> some strange output occurs:
> Menu for /gdp/html_grass5/html/p.map.html
> html
> [an internal server error occured]
> Obviously these pages are treated as something different
> (PHP?).
> Any ideas to solve this? The HTML code is o.k., I think.
It doesn't matter whether or not the HTML code is OK. Even if you give
a ".html" extension to a file of completely random binary data, it
shouldn't cause an internal server error.
My suspicion is that the server has been configured to treat any
filename which contains[1] the string ".map" as a server-side image
map.
[1] as opposed to ending in ".map".
Glynn Clements <glynn.clements at virgin.net>
