[GRASS5] network traffic
Roger Miller rgrmill at rt66.com
Sat Jan 26 12:08:59 EST 2002
Folks,
I run GRASS (5.0.0pre2) through ssh on a ppp connection to my installation at
the office.  I used the command line interface.  When I start a monitor the
lag between keystrokes and displayed results often increases.  Starting a
second monitor virtually stops everything.  The lag between the time a key is
pressed and the time it appears on the screen sometimes exceeds 30 seconds.
I started pppstat on my local machine to see what was going on, and found
that the first monitor generated a continuous stream of network traffic at
about 8kb/second incoming and 4-5 kb/s outgoing.  Somewhat bizzarly, starting
a second monitor dropped that stream to about 5 kb/second incoming and about
200 bytes/s outgoing.  The command shell slowed to a near halt.
After I stopped the second monitor the network traffic initially stayed at
about 4 kb/s incoming and 200 bytes/s outgoing, but the traffic later rose
fairly gradually back to about 8 kb/s incoming and 4-5 kb/s outgoing.
All of this behavior is with a blank monitor--nothing at all in the display.
The behavior is the same regardless of whether the monitor is raised or not.
For comparison, "xeyes" running over the same link and taking a continuous
stream of mouse events generated about 1/10 that much traffic.  "xcalc"
running over the same link generated no traffic at all when it wasn't being
used.
I tried with a second installation at my office that was based on a CVS
download from last August.  That appeared to have the same problem.  I have
until recently been using a beta11 installation and never noticed the problem.
What's going on here?  Is this problem unique to my installations or is this
a consistent behavior?
Roger Miller
