[GRASS5] network traffic
Chris Marshall chris.marshall at wrx-us.com
Sat Jan 26 14:21:40 EST 2002
 I dont' know what is going on but a really nice way of running chatty X
programs remotely over thin, high latency network pipes is with VNC.
-----Original Message-----
To: grass5 at grass.itc.it
Sent: 1/26/02 12:08 PM
Subject: [GRASS5] network traffic
Folks,
I run GRASS (5.0.0pre2) through ssh on a ppp connection to my
installation at
the office.  I used the command line interface.  When I start a monitor
the
lag between keystrokes and displayed results often increases.  Starting
a
second monitor virtually stops everything.  The lag between the time a
key is
pressed and the time it appears on the screen sometimes exceeds 30
seconds.
I started pppstat on my local machine to see what was going on, and
found
that the first monitor generated a continuous stream of network traffic
at
about 8kb/second incoming and 4-5 kb/s outgoing.  Somewhat bizzarly,
starting
a second monitor dropped that stream to about 5 kb/second incoming and
about
200 bytes/s outgoing.  The command shell slowed to a near halt.
After I stopped the second monitor the network traffic initially stayed
at
about 4 kb/s incoming and 200 bytes/s outgoing, but the traffic later
rose
fairly gradually back to about 8 kb/s incoming and 4-5 kb/s outgoing.
All of this behavior is with a blank monitor--nothing at all in the
display.
The behavior is the same regardless of whether the monitor is raised or
not.
For comparison, "xeyes" running over the same link and taking a
continuous
stream of mouse events generated about 1/10 that much traffic.  "xcalc"
running over the same link generated no traffic at all when it wasn't
being
used.
I tried with a second installation at my office that was based on a CVS
download from last August.  That appeared to have the same problem.  I
have
until recently been using a beta11 installation and never noticed the
problem.
What's going on here?  Is this problem unique to my installations or is
this
a consistent behavior?
Roger Miller
grass5 mailing list
http://grass.itc.it/mailman/listinfo/grass5
