[GRASS5] configure goof?
David D Gray
ddgray at armadce.demon.co.uk
Sun Jan 27 22:48:16 EST 2002
Glynn Clements wrote:
> David D Gray wrote:
>>>>This is picking up Tcl/Tk for TkStep, an old version I still require in
>>>>/usr/local/*. I tried to configure as you can see that it would pick up
>>>>the correct 8.3 libs in /usr/* (I actually have 6 Tcl versions scattered
>>>>about). Then I noticed that this only appends the include and lib
>>>>directories specified. If that is the case, it seems wrong to me: the
>>>>`--with-tcl-incudes' should specify where to look, or at least prepend
>>>>the specified directory. I notice the tiff libs are searched the same
>>>>way, perhaps all search paths are specified this way. If so, can they
>>>>all be changed?
>>> I've fixed the configure checks.
>>It's still picking up the headers in the /usr/local/include directory.
>>However if I disable these temporarily, the correct headers in
>>/usr/include are found.
> I think that you're experiencing gcc's default header search path:
> /usr/local/include
> /usr/<platform>/include
> /usr/lib/gcc-lib/<platform>/<version>/include
> /usr/include
> If you install headers into /usr/local/include, they effectively
> supersede any corresponding headers in /usr/include. In general, don't
> install headers into /usr/local/include if you want to still be able
> to use the versions from /usr/include.
> You can force the addition of -I/usr/include with:
> --with-tcltk-includes=/usr/include
And therein lies the problem. It was my goof after all. I put
`--with-tcl-includes' instead of `--with-tcltk-includes', and so
happened as you describe. Presumably because, with so many variants of
Tcl/Tk around, I'm so used to it.
But that raises another question. Shouldn't configure stop if a
wrong option is supplied? I have seen that on many configure runs in the
past, with various projects' sources.
David
